Pardon me while I grab my ankles. - NCRS Discussion Boards
  • G B.
    • December 1, 1974
    • 1407
    Despite what you read in eBay auctions, Delco does still offer new gas gauge sending units for '63 - '67 Corvettes. You really don't have to buy one of those $80 foreign-made senders. However....
    THE DELCO LIST PRICE FOR MID-YEAR SENDERS HAS GONE UP TO $387 EACH! Net price is now just under $200. Yowzah!
    The current Delco calibration is the same so-so quality I've been seeing for the last five years. The sender I picked up today has a resistance range from 2 to 115 ohms rather than the 0 - 90 ohm original spec. That's sorta close.
    Oh Baby, Baby! Take me here! Take me now!
  • Gerard F.
    • June 30, 2004
    • 3805
    Tell the doc
    to use two fingers, cause you want a second opinion.
    And where is the Delco made?
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
    • G B.
      • December 1, 1974
      • 1407
      #6428065 / 6425827
      The sender box bears part #6428065. The sender itself has a sticker that reads "Service Sender P/N 06425827". Neither the box nor the sender label name a specific country of origin. All label wording is in English.
      Many Delco parts are now made in Mexico, China, India, and Hong Kong. Those parts made outside the U.S. are labeled as such. I think it's the law.
      • G B.
        • December 1, 1974
        • 1407
        Cheap gas gauge senders
        I haven't tried any of the $80 senders in a few years. When they were first sold in the U.S., they didn't work.
        Has anyone tried one recently to see if the design flaw has been fixed?
        • Bill Stephenson
          Re: Cheap gas gauge senders
          Jerry,
          -------Ill get out, take the cap off, and look before I ever pay that much money for a gas guage............Bill S
          • Gerard F.
            • June 30, 2004
            • 3805
            Re: Cheap gas gauge senders -Tried one
            Jerry,
            I tried one last year with a new gage. Worked good for about 6 months. Now it only works between 3/4 full and full, seems to get stuck on 3/4 full. Is that the design flaw?
            Thinking about refurbing my original which I saved. It's only flaw was a broken electrical connection to the variable resistor.
            I see that Paragon has an OEM sender listed for $220.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
            • Donald T.
              • September 30, 2002
              • 1319
              I've encountered the problem of a gas gauge not reading below a certain level. Sometimes the float hangs up and does not go down all the way with the fuel. I've been able to reach down in the tank and manually manipulated the float through it's range of motion. Seems to free it up if that's the problem.
              • G B.
                • December 1, 1974
                • 1407
                The very first ones from China or Korea (or wherever) had a dead short to ground! Really.
                The next batch worked for a little while but the variable resister contacts quickly corroded and then they would quit.
                • Gerard F.
                  • June 30, 2004
                  • 3805
                  Don,
                  Have tried pushing it up and down, and it works.... for a while. Then it reverts back to the 3/4 full to full reading. Also thinking about putting a floating boot over the float to give it a little more force, up and down.
                  Jerry Fuccillo
                  Jerry Fuccillo
                  • Clare Carpenter
                    What's involved in restoring originals??
                    Interesting thread. This is one project in my restoration that I haven't gotten around to yet. My original tank is very good shape, inside and out and the sender worked fine prior to the tank being drained and removed. Since then it has been sitting on the parts shelf. I had planned on replacing the sending unit. I've seen them available from the various vendors for just under a $100 for my '62. This thread has educated me to the availability of Delco's at over $200, which are also apparently sourced offshore. Being aware of the quality issues with the no-name cheapies and the expense, and possible quality issues of foreign sourced Delcos, I'd rather restore what I have. Has anyone done this and what's involved? Can needed parts. if any, be purchased? Thanks for any insight provided.
                    • G B.
                      • December 1, 1974
                      • 1407
                      Clarifications
                      My post was about mid-year sending units only. They're different from the design used in your '62, and they've always been more expensive.
                      A couple of years ago a Delco mid-year sending unit cost about $140 net. Now they're $200 net. Two years ago the '62 sending unit was available and cost about $60 net. I haven't checked, but my guess is that it is still available and now costs about $80 net.
                      I do not know where the current Delco mid-year sending unit is made. I assume it is made in the U.S. since it is not identified as being made in another country.
