67 T.I. Distributor - NCRS Discussion Boards
67 T.I. Distributor
  • Richard S.
    • November 1, 1994
    • 809
    67 T.I. Distributor
    I'd like to verify the integrity of the small off white wires that run from the T.I. pick up coil to the T.I.harness. It seems this wire is NOT reproduced and you can only get it with a new pick up coil....very expensive. While searching for one at Bloomington I met a man with an NOS coil for sale. He said I should check the wires for between 500 to 700 ohms with an ohm meter. My ohm meter does not seem to register properly....it only shows 1....when I touch the two probes of the ohm meter to the two inside terminals in the connector which plugs into the T.I harness. Can anyone offer any suggestions.....thanks.
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 67 T.I. Distributor
    Rick - I think the 500-700 ohm range is correct if I recall. I would get a known resistance and check your meter first ( a small resistor would do in that range from an electronics supply house). You don't mention if you have a functional problem, but your reading would indicate an internal short of the wound coil, and this would fail to trigger the igniton. You may find more diagnostic information on Dave Fiedlers TI specialty website...Craig
    TI Specialty
    • Clem Z.
      • January 1, 2006
      • 9427
      i have repaired those broken wires BUT
      to NCRS specs.
      • Clem Z.
        • January 1, 2006
        • 9427
        forgot the word "not" sorry *NM*
        • Clem Z.
          • January 1, 2006
          • 9427
          one wire has a green stripe
          and a ohm meter is the best way,connect it and wiggle and pull on the wires to see if they show open. if you reverse the white and white with a green stripe you will have a miss or a surge at higher RPMs
