65 Wiring Question - NCRS Discussion Boards
65 Wiring Question
  • Ben L.
    • May 31, 2004
    • 11
    65 Wiring Question
    I am replacing all of the wiring harnesses with new ones from Lectric Limited. Which of the dash wires are fed through the grommet (shared with the oil pressure line) into the engine compartment and where do those wires go? Any help would be appreciated.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 65 Wiring Question
    Hopefully your new wiring is taped together. The wirng would include the coil/ballast resistor, wiper motor, heater motor and a lead to the starter....
    • Eugene B.
      • May 31, 1988
      • 710
      Ben,
      If my memory is correct, there were two larger purple wires coming through the hole next to the oil pressure line. They plug into two mating connectors that are part of the firewall harness.
      Hope this information is helpful.
      Gene
      • Jack W.
        • August 31, 2000
        • 358
        and if so equipped, back-up light switch wires need to come through firewall . . . .
