1965 Carpet - NCRS Discussion Boards
1965 Carpet
  • Dave Marshall
    1965 Carpet
    I am ready to attempt to install the carpeting in my 65 conv. with an Al Knoch carpet set. Is there a good detailed set of instructions anywhere that I might get to help me with this project? I am a first timer at this and want to do it right. Any help is appreciated. Thanks.
    Dave Marshall
  • Art A.
    • June 30, 1984
    • 834
    Re: 1965 Carpet
    Dave, What color carpet and when did you buy it from Al?
    Art
    • Dave Marshall
      Re: 1965 Carpet
      Art,
      The carpet is black and I actually bought it at the 1995 Homecoming at Bowling Green, KY. Thanks.
      Dave
      • Douglas L.
        • August 31, 2003
        • 299
        Re: 1965 Carpet
        Dave,
        On the seats, remove the seat brackets from the bottom the seats and use them as a template for cutting the bolt hole locations for the seats. Also, be careful of how much you cut around the center console area. That is where I had a slight overcut when I did mine. Use a heat gun to warm the carpet up to make it lay flatter. Measure 10 times, cut once!! Good luck.
          Thoroughly clean & dry...
          the bottom of the carpet to remove any residual plasticizer that'll prevent glue/adhesive from sticking the carpet to the underlying jute. Also, laying the carpet flat and letting the sun 'cook' the wrinkles from pack out of it helps too...
