delco coil - NCRS Discussion Boards
delco coil
  • mike mccagh
    delco coil
    can anyone identify application for the following delco remy coil with delco part # embossed 1853907 ? currently on a 32 dodge 8 cyl sedan. has in gition key built into the end opposite the bakelite tower. thanks, mike
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: delco coil
    1932/34 olds and pontiac
    • Mike M.
      • May 31, 1974
      • 8403
      Re: delco coil
      thanks clem. do you know if the 32-34 oldsmobiles had the ignition switch an integral part of the coil ? thanks, mike
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: delco coil
        all i could find was the listed car use for the coil, no listing about the key
