C3 - 350 lifters - NCRS Discussion Boards
C3 - 350 lifters
  • Jim Callan
    C3 - 350 lifters
    When I installed new lifters... I forgot to "squirt" oil in them. Will I be able to set the preload on the lifters ? I know they'll be noisey on start up but the pre-lube should help. Do I need to re-do this step ?
    Jim Callan
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: C3 - 350 lifters
    if you are talking about hyd lifters you are better off no filling them with oil before setting preload because sometime with oil in them the pushrod cup will not depress. just use a drill driven oil pump primer and you will be OK
    • Jim Callan
      Thanks Clem - just what I wanted to hear !! *NM*
