283Ttruck engine vs. 283 Corvette engine - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    Was the interior make up of the 1959 283 truck engine (cam, pistons, ect.) the same as the 283 corvette engine? Thanks, Jimmy
  • William C.
    • May 31, 1975
    • 6037
    Re: 283Ttruck engine vs. 283 Corvette engine
    In terms of the shortblock, it appears the same parts were used.
    Bill Clupper #618
      • 43221
      Jimmy-----
      It depends what you mean by "truck". If you're talking about a light truck application (series 10-30) then the engines were pretty much the same as car.
      However, MD and HD truck applications usually used a "roller" type chain and used hardened exhaust valve seat inserts in the heads.
      • Dick W.
        • 10483
        If the Corvette is a base engine car I think most parts would be the same. If it was a high performance engine the pistons and camshaft would be different.
        Dick Whittington
