C2-Rear Spring Clamps - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hello All,
    My replacement 7-leaf rear spring for my '66 has clamps (bands) on the spring to hold it together. Can these bands just be removed?
    As usual, thank you for you help and advise.
  • Dick W.
    • 10483
    Re: C2-Rear Spring Clamps
    Remove the bands. No C-2 or C-3 Corvette, as delivered from the factory, had bands on the springs
    Dick Whittington
    • Gary B.
      • February 1, 1997
      • 7007
      Kurt,
      If your spring has the correct H-shaped polyethylene liners betweeen the leaves, then, yes, the clamps can be removed. If you don't have the correct liners, then you can still purchase them from GM (part # 3794113), but be prepared for sticker shock. GM list price is $13.67 each. GMpartsidrect.com sells them for $7.79 each, but it will cost you another $8 for shipping & handling.
      Gary
        If the replacement spring came from Eaton or JRS, the bands are only for shipping, and should be removed after the spring is installed.
        • R N.
          • May 31, 2002
          • 640
          Guys, the spring is a replacement, not sure of where it was purchased from. I do have the correct liners and the spring looks correct other than the bands.
          I'll remove the bands.
          Thank you again,
          Kurt
          • Randy Adams
            John...What if
            ....the springs aren't from either of those companies?
              Re: John...What if
              Randy -
              If the leaves are the correct width and have the "H"-section liners in place, there is no need for the clamps; the width of the leaves is trapped between the attaching bolts once installed.
