C1 Side Window - NCRS Discussion Boards
C1 Side Window
  • Allen W.
    • September 30, 2000
    • 106
    C1 Side Window
    I need some help. I am trying to adjust my drivers side window on my 56. I have the glass out so i can rebuild some things. While I am at it I want to install the doors glass seal I bought some time ago. My existing glass has no traces of the old seal. Looking at the 57 AIMS and the Paragon and Corvette Central catalogs I'm having a hard time seeing where this seal goes. ST 12 is no help. Does this seal go between the glass and the metal sash? There is some rubber there but no traces of the portions of seal. If I am correct I guess the wide rubber "trough" goes toward the outside door skin side. Is an adhesive used. If my guess is wrong please help.
    Allen
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Allen, I believe...
    ...you have it pretty well figured out. No adhesive required. Everything is a tight enough fit as is. Good luck... Dennis
