C 1 Transmission Numbers - NCRS Discussion Boards
  • Larry W.
    • April 7, 2008
    • 54
    The transmission in my '58 has a T10 - 1C Case and a T10 - 7D Tailshaft. The stamped numbers are WM42-2 & A132522 will somebody please tell me the real application of the unit. By the way, ebay has a listing of a bellhousing like my '60 for $20. It seems as though there is not much of a market for rere bell housings.
    Thanks in advance.
    • 43221
    Re: C 1 Transmission Numbers
    Larry-----
    The numbers would indicate that you have a 1962 T-10 which could have been originally used for any 1962 application.
    The 1960 Corvette bellhousing is the least common of all Corvette bellhousings. Of course, it's only real value is to someone needing such a part. As far as the eBay listing is concerned, is the $20 the CURRENT price or is it the CLOSING price. There's often a big difference.
    • Mike E.
      • February 28, 1975
      • 5138
      W=Warner
      M=December
      4= 4th day of the month
      2= 1962
      2= second shift.
      Serial number indicates a non-corvette. This would have come in a 1963 GM passenger car of some sort.
      • Larry W.
        • April 7, 2008
        • 54
        Thank you Both!
        I'll keep my eye on the bellhousing.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          Re: Thank you Both!
          A 1960 bellhousing for $20 would be about 10X less than market last time I checked...
