C1 Emergency brake cable - NCRS Discussion Boards
  • Justin B.
    • March 1, 1996
    • 478
    My reproduction (Paragon) emergency brake cable will not fit properly at the bracket which is welded on the frame and holds the metal housing of the cable secured by a nut and bolt, not even after some mild modifications on both the frame bracket and the cable. Does anyone have an NOS that they would be willing to sell? Thanks Gang!
  • Chris H.
    • April 30, 1990
    • 817
    Re: C1 Emergency brake cable
    I am pretty sure GM still has them in stock. Probably the ones Paragon sells.
    Chris
    • Chris H.
      • April 30, 1990
      • 817
      front park cable 3706146
      rear park brake cable(2) 3711840
      • John O.
        • May 31, 1998
        • 480
        I have a 62 and they should be the same. I bought mine from corvette central and it fit good. Works good too.
        John
