67 Seat Belts - NCRS Discussion Boards
67 Seat Belts
  • Donald W.
    • August 12, 2013
    • 190
    67 Seat Belts
    Dear Board Members,
    Could someone tell me what the date letter E stands for. My early 67 has dates 41 E 66, the 41st week of 1966, model # C 10 Hamill 1967. Also was Hamill the supplier for other makes than Corvettes.
    Don
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 67 Seat Belts
    Someone said on this forum a while back that the E was a section of the Hamill plant where the seat belt was made. Many had told me it was for Friday but their was almost all E's that I had seen.
    Lyle
    Lyle
    • Gerard F.
      • June 30, 2004
      • 3806
      Re: 67 Seat Belts
      Don,
      Lots of differing opinions on the "E" in the archives. Some say it was for Friday, others, the seat belt assembly line, or a model code. Has anyone seen 67 seat belts with other then an E code. Maybe they only did Corvette seat belts on Fridays, or maybe they only stamped them on Fridays for a weeks shipment.
      I don't think we ever got this resolved.
      Hamill was the supplier for other GM cars and I believe other manufacturers. You see that same RCF-65 seatbelt buckle (with a different insert) as deluxe seatbelts on other GM models. Robert C. Fisher, a GM employee, held the patent on the RCF-65 and later RCF seatbelt buckles.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Barbara S.
        • April 30, 1981
        • 599
        Re: 67 Seat Belts
        Here's how mine read:
        Female:
        HAMILL 1967
        MODEL # C10
        Male:
        HAMILL 1967
        MODEL # C10
        15E67
        If someone can decipher this, please do so.
        Tony
        • Don 42616
          Re: 67 Seat Belts
          My 67 belts read a little different. I do not know interpetation. Male end reads. Don
          Hammil C-10
          1967
          22E76
          • Gerard F.
            • June 30, 2004
            • 3806
            Re: 67 Seat Belts
            Tony,
            Those are the 15th week of 1967, and I'll bet that male belt is on the passenger side. The model is correct for 67 lap belts.
            My original belts for a June 29, 67 conv were only date stamped on one belt, the passenger side male belt and the date was 7E67 (7th week 67). I thought this was odd, and when I refurbed them, I looked at each label in a bright light and under a magnifying glass, looking for any remnants of the date stamp. Nada, either they used disappearing ink or they were never stamped.
            Don, 22E76 would be 1976 replacement belts. There are lots of replacement belts out there as there was a big lawsuit or lawsuits in regard to defects in the original belt buckle, called "inertial unlatching". I put a set of 1976 buckles on my original 67 belts, and they are identical to the 67's but have a little stronger pawl spring.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
