Repairing Pitted Suspension Parts - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    What have you all found to be the best way to fill small to moderate rust pits in the frame and suspension pieces prior to painting? Thanks.
  • John O.
    • May 31, 1998
    • 480
    Re: Repairing Pitted Suspension Parts
    Hi Greg
    When I was restoring my car I found after sanblasting the frame,some pits. I used an epoxy that bonds to metal.After sanding and painting it, it looks good.No problems. I don't remember the kind I used, it was 7 years ago. But go ask at a body and paint supply store. I'm sure they can help you.
    John
    • mike geary
      Greg: Get yourself some "Slick Sand" or "Poly-Prime" catalyzed polyester primer. Spray it on, let it cure for 24 hours, then block sand it out. Fills pits great. Much easier than trying to butter all the pits up with a glazing compound by hand.
      • Dave K.
        • November 1, 1999
        • 952
        Depending on the depth of the pits the catylized primer/filler may not work by itself unless you continue to build it up. I used Evercoat final filler followed by a sprayed on catylized primer/filler and topcoated with Rustoleum.
        Dave Kitch
        33108
        • Greg L.
          • March 1, 2006
          • 2291
          Thanks Guys...that's all good advice.
