c1 oil dripping - NCRS Discussion Boards
c1 oil dripping
  • paul bowers
    c1 oil dripping
    on my newly rebuilt 57 engine, when I crawled under the car there is a slight black oil drip coming from around a starter bolt area and running down the transmision clutch pan cover very slight but I know it has to come from somewhere, please dont't say that it requires major work just did (major) work
    thanks for your imput
    paul
    • 43231
    Re: c1 oil dripping
    Paul-----
    TWO distinct possibilities:
    1) Valve cover gasket leaks which "work their way down";
    2) Rear main seal leak. A very strong possibility if you're using the original "rope-type" packing.
    • Wayne P.
      • August 31, 1975
      • 1025
      Re: c1 oil dripping
      Could be the intake manifold gasket, but most likely the road draft tube at that area, which would make it normal.
      • paul bowers
        Re: c1 oil dripping
        joe,
        don't know what rope type, but I had engine completly out of car and completly rebuilt I mean everything new, lets hope it what other responder thinks draft tube blow by, but just asking what is involved in replaceing rear seal, does engine have to be taken out and also how can I determine if it is draft tube oil thanks
        paul
          • 43231
          Re: c1 oil dripping
          Paul-----
          It could very well be the road draft tube as Wayne mentioned. If you check the end of the road draft tube, you should find some oil. This could be where the other oil is originating. I don't know how to confirm that it is, though. One thing that, I suppose, you could do is to temporarily add a piece of rubber hose to the bottom of the draft tube in order to get the discharge to a lower point. Then, if the other oil problem clears up, you'll know that's the source.
            • 43231
            Addendum
            You don't need to remove the engine to replace the rear main seal if it should come to that. And, you obviously don't need to remove it to repair a valve cover gasket or intake manifold end seal leak, either.
            • Robert Willis
              Re: Addendum
              Oil pressure line leaking by the dist or no paper gasket under the dist ?????
              Bob's Chevy Corner
              • Rob Dame
                Re: c1 oil dripping
                Don't worry too much about a slight leak, These old cars are almost as bad as old Harleys when it comes to leaks. Drive it and enjoy it.
                When it starts to leave puddles the leak will be easier to find Rob
                • paul bowers
                  Re: c1 oil dripping
                  thanks to all you guys for all your imput you always have great advice
                  paul
                  • Clem Z.
                    • January 1, 2006
                    • 9427
                    road draft tube oil leak
                    if you have a lot of oil comming out of the RDT better check to see if the "beer can" baffle is inside the tappet chamber
