2" heat riser - NCRS Discussion Boards
2" heat riser
  • Chas Henderson #28127
    2" heat riser
    Hi all, what is the best way to free up - clean the butterfly valve? Use WD-40 and just work it back and forth? I read in my service manual about some kind of cleaner, but not realy sure what they were talking about. Mine works, but is getting a little stiff.
    Chasman
    • 43221
    Re: 2" heat riser
    Chasman----
    Use GM #1052627 heat valve lubricant. It's the best thing ever available. It's also one of the best things you can use to free up frozen bolts, nut, etc. Not if you live in California, though. It's no longer sold in California due to air pollution regulations.
      Re: 2" heat riser
      Thanks, Joe. I'm in Indy so I will order some this week.
      Chasman
