E bay: 67 motor decked ! - NCRS Discussion Boards
  • Don 42616
    What a shame. Beatiful optioned car. Can not put back what has been taken away! http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
  • Don 42616
    Sorry wrong car
    Try this. http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
    • mike mccagh
      Re: Sorry wrong car
      ok, you midyear guys, tell me what's not corredt under the hood.lots of inconsistencies.see if the c-2 critiquers can match those of the recent posting of the good rev. mike. mikie
        • 43221
        Re: Sorry wrong car
        Mike-----
        I'm not, necessarily, what one would call a "C2 guy" but here are some observations anyway:
        1) valve covers are incorrect for 1967 Corvette, including push-on style oil filler cap (73-74 configuration);
        2) Tonawanda label on the wrong side;
        3) heater hose and bypass hose clamps incorrect;
        4) radiator cap incorrect;
        5) PCV valve and hose incorrect (1971+ style);
        6) a/c foam element incorrect style and installation;
        7) master cylinder incorrect, non-bleeder style.
        I'll bet there are a lot of other things I can't see in the photos.
        • Warren F.
          • December 1, 1987
          • 1516
          Re: Sorry wrong car
          If it's a California car, isn't it supposed to have A.I.R?
          Also I'm always intrigued, when someone says the engine is built to factory specs, NOT possible if decked or milled or bored. People need to realize once the engine is played with, IT's NEVER factory correct AGAIN!
          • Wayne P.
            • August 31, 1975
            • 1025
            Re: Sorry wrong car
            Factory specs means tolerances, clearances, torques, etc. NOT original!
            • Justin N.
              • February 1, 2004
              • 318
              Re: Sorry wrong car
              I don't like the looks of those small blue zipstrips on the alternator feed wires. I don't know about the yellow sticker either. My original 67 coupe door panels from Aug 1966 had a single screw in each panel securing near outer edge.
              Justin
                Re: Sorry wrong car
                In addition to the above comments:
                Front springs are shot.
                Wrong upper radiator hose
                Wrong radiator cap.
                Wrong radiator upper tie bar configuration.
                Wrong/spliced heater hoses.
                Wrong A/C refrigerant hoses and (crimped) connections.
                No blackout on hood hinges.
                Wrong arrangement of plug wire shield grounds.
                Wrong bolt securing brake distribution block to bracket.
                Wrong pedal pads.
                Aftermarket radio.
                Dash panel end tabs in door opening should be painted green.
                • Brian M.
                  • February 1, 1997
                  • 1839
                  Re: Sorry wrong car
                  Not to mention a screw missing from the door panel's and the wrong A/C high and low caps.
                  • Del S.
                    • March 1, 1991
                    • 83
                    Re: Sorry wrong car
                    wheres the stingray emblem on rear
                    • Brian M.
                      • February 1, 1997
                      • 1839
                      Re: Sorry wrong car
                      Good Eye. Must be the emblem delete option.
                      • Bill Stephenson
                        Re: Sorry wrong car
                        -------Geez,,,,,,,Nobody mentioned the incorrect intake on the yellow car????? You guys are slipping..........Bill S
