1964 Turn Signal Flasher model number??? - NCRS Discussion Boards
+ More Options
Posts
  • James W.
    • December 1, 1990
    • 2662
    What is the correct model number of the turn signal flasher for a 1964 Corvette without back-up lights? Is it a Signal Stat 145 and rectangular or round in shape?
    James West
  • Scott Butville
    Re: 1964 Turn Signal Flasher model number???
    James, The TIM&JG calls for a Tung Sol AP373V (round aluminum) or a Signal Stat 143 (rectangular, various colors).
    • James W.
      • December 1, 1990
      • 2662
      Scott,
      Thanks for the info.
      James West
      • Robert Jorjorian
        James
        The JG stating a Signal Stat 143 is not correct. A 143 is for 1963 (except B.U. lights) not 1964 unless you choose to use 1034 bulbs instead of the correct 1157 bulbs that a 1964 originally used.Check your owners or shop manual if you doubt the bulb usage.
        Regards, Robert
        • James W.
          • December 1, 1990
          • 2662
          Robert,
          Thanks for the information, I'll check my shop manual, owners manual and assembly manual to see what they have for information.
          James West
          • Michael H.
            • January 29, 2008
            • 7477
            Scott,
            Does the JG call for a 143 for both 63 and 64?
              Yes, JG calls for Tung Sol AP373V or Signal Stat 143 for both '63/64 Corvettes without BU light. This seems to ignore the TS flasher change called out in the AIM which was released 6/6/64 incorporating the flasher PN's used in the '65 model year....
              • Michael H.
                • January 29, 2008
                • 7477
                Thanks Jack. I'm trying to help someone prepare a 64 for judging and wanted to recommend the JG advised flasher, even if it is incorrect. He can reinstall the correct original unit after judging. I suppose that means changing all of the bulbs to 1034 also.
                • Scott Butville
                  Yes *NM*
