TI coil - NCRS Discussion Boards
TI coil
  • howard
    TI coil
    TI coil #1115205 is this a rare one? it is NOS and embossed 207 12V
    thanks
  • Gene M.
    • April 1, 1985
    • 4232
    Re: TI coil
    Sorta is rare, It is used on small blocks with T.I. and there are not a lot of them out there.
    • Wayne M.
      • March 1, 1980
      • 6414
      Re: TI coil
      Howard --- As Gene says (sorta rare), but as it was used as the service replacement for all the other TI coils, they are out there, ranging from $150 to $275. The emboss (deboss ?) is located about 1" from the bottom of the can, with the 12V directly below the 207. If you still have the box, it should be identified as 1115207 with the Delco part # D-514. Where did you get the # 1115205 ? Don't think that coil ever got released.
      • howard
        Re: TI coil
        wayne right you are!1115207 MY error thanks for $$$ info,howard
        • Jimmy G.
          • November 1, 1979
          • 976
          Re: TI coil
          Nice piece but not extremely rare. Small block OEM and over the counter service replacement for all ti applications.
