C-1 Clutch and Pressure Plate - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Noticed Clutch kits are different for FI/Hi-Perf. than standard kits. Anyone know the difference? Thanks in advance.
    • 43221
    Re: C-1 Clutch and Pressure Plate
    Jerry-----
    GM never originally used different clutches for different engines in the C1 era. In fact, all 1957-62 Corvettes, regardless of engine used, basically, the same clutch set-up. There were some part number changes over the years, but the basic specs didn't change.
    In the aftermarket for replacement clutches these days, I suppose that they may offer different pressure plate spring pressures, with the HP engines getting a higher spring pressure.
    • Dennis A.
      • April 30, 1999
      • 1010
      All 56-62's use a 3 finger clutch, Isn't the other offering's for a multi-finger replacement? I know that a 10 3/8 inch clutch disc is recommended for higher horse power engines over the original 10 inch, could this be the reason for the two offerings?
        • 43221
        Dennis-----
        I think that most, if not all, of the currently available C1 replacement clutches are diaphragm style units (i.e. "multi-finger"). The friction disc size could be another difference between the available units.
