transmission /steering column lock 70-72 - NCRS Discussion Boards
  • lyndon sharpton
    how does the cable lock work on these cars, as mine is not hooked up. does it lock it in a gear?
  • William C.
    • May 31, 1975
    • 6037
    Re: transmission /steering column lock 70-72
    When shifted into reverse, the column is locked if the key is off.
    Bill Clupper #618
    • lyndon sharpton
      so it is locked in reverse, an you can not put it in any gear until you trun the on?
      • William C.
        • May 31, 1975
        • 6037
        Actusally the steering column is what locks, when the shifter is place into reverse, and I think that allows the key to be removed. I think the owners manual covers the way it operates.
        Bill Clupper #618
          Key won't come out of the ignition until the trans is shifted into reverse + the steering column will be locked into position and trans will be locked into reverse until the ignition key is re-inserted. The operation of the theft deterrent system is covered in your copy of the NCRS 1968-72 Corvette Operations Manual & PV Test Guide....
