Differential Case Part #'s - NCRS Discussion Boards
  • Gregory G.
    • July 31, 2001
    • 203
    The part numbers 0J357W7E1 are located on the cases bottom forward of the cover.The cover date code,top right is E149.
    What is the gear ratio,and is this a service or production part?
    Greg
    • 43221
    Re: Differential Case Part #'s
    Greg-----
    I believe that it's a PRODUCTION unit. However, I think that PRODUCTION and SERVICE assemblies were coded the same, so there is no way to know, for sure. The "OJ" code indicates a 3.70:1 ratio used from 1978 through 1979, although there's no guarantee that those gears are in the case now. The remainder of the coding would indicate a unit manufcatured during the 1979 model year.
    • Gregory G.
      • July 31, 2001
      • 203
      Joe,
      The front cover date code E149.You are saying its a '79 not '69 due to the Case part#.The E stands for Eaton,but the W stands for Warren?Could it have a '69 cover?
      Greg
        • 43221
        Greg-----
        All 63-79 Corvette differential units were manufactured at Warren, MI and all except 63-64 used an Eaton posi unit. So, that information doen't mean very much. The "OJ" code was only used for 1978-79. So, it has to be one of those years.
        • Gregory G.
          • July 31, 2001
          • 203
          Joe,
          Does a 78-79 cover spring bolt pattern align with a 69-70 spring bolt patten?My 9 leaf factory original spring fits properly to the rear differential cover,so the E149 cover casting date may then be a 69 not a 79,which then means differential covers are interchangeable for those years,but the OJ stamping as you stated is 78-79.Do you agree?
          Greg
            • 43221
            Greg-----
            The 78-79 cover will fit perfectly to a 63-77 Corvette application. In fact, the 78-79 cover became the GM SERVICE cover for all 63-79 applications after the earlier style was discontinued. The 78-79 cover is easily identified, too. For one thing, it carries the casting number "464910". For another thing, the 4 spring bolt holes are 7/16-14 thread size. The 63-77 covers were originally 9/16-12 thread size. The change in bolt size was for the purpose of accomodating the 2-1/2" wide spring used for some 1978-79 Corvettes. When the 78-79 cover is used on an application with a 2-1/4" wide spring, such as any 63-77 application, special spacers have to be used to "take up the slack" between the bolts
