Questions on available options 65-67 - NCRS Discussion Boards
  • Paul Reynolds
    Here's my 2 questions..
    1. Was the 65-67 327/350hp ever available with both power steering and air conditioning?
    2. If so, did that option use the SHP deep 2 groove pulleys on the crank & waterpump, 1 groove deep alt, and 1 groove deep P/S pump or revert back to the standard depth pulleys like the 300 hp cars?
  • Paul Reynolds
    Re: Questions on available options 65-67
    OK, Next question.. Anyone have a pic of a stock L79 with P/S and A/C? 65-67 is what I'm looking for. (if it exists)
    Please send to my email: Subfixer@comcast.net
    Thanks.
    • Loren L.
      • April 30, 1976
      • 4104
      Yes to question 1. Question 2 may be too
      broad in that there might have been a variety of changes in the 3 years. Noland's book should have some pictures.
      • Craig S.
        • June 30, 1997
        • 2471
        Re: Yes to question 1. Question 2 may be too
        My 67 L79 has C60, N40, and K19 A.I.R. It has the deep groove pulleys on the crank and water pump, but the PS pump uses the stamped steel (509?) pulley, not the cast iron unit. The alternator uses the deep groove pulley, but if I recall it is the offset version due to the groove that aligns correctly....one belt forward. It is up on a lift with the rear end out.....and a car underneath so I can't check....Craig
        • Paul Reynolds
          Craig, when and if you can, I would really appreciate a picture or two of the pulley/belt routing. Is your Alternator belt on the groove closest to the block? Also, do you have 2 grooves or 3 on the crank pulley and where does the P/S belt run? I'm going to install A/C in my car on the corrects mounts, and I would like to use the belt/pulley arrangement that GM designed. Thanks.
