C3 (72) Should Belt removal - NCRS Discussion Boards
  • Joe S.
    • July 31, 1999
    • 319
    I have teh seats out of my 72 and the belt dangling from the retracter. IS there some easy way to get the belt through the seat? The rubber that prevents it from going back would be a tight squeeze through the hole. I am redoing the seats and the belts and need to separate them.
  • Joe S.
    • July 31, 1999
    • 319
    Re: C3 (72) "Shoulder" Belt removal!! *NM*
    • Warren F.
      • December 1, 1987
      • 1516
      Re: C3 (72) Should Belt removal
      Joe:
      The plastic cover should be gently heated up with a hair blower, until warm to the touch, then remove it from the metal buckle end and push the shoulder belt thru the slot in the seat back.
      • Joe S.
        • July 31, 1999
        • 319
        Too easy. Took about 1 minute with a heat gun. Thanks!
