C3 (70) Head Gasket type? - NCRS Discussion Boards
  • Travis Williamson
    What is the best type or prefered head gasket to use?
    The metal type or something like the Fel-Pro PermaTorque?
    Could you list the advantages and disadvantages for both?
    Also, would you re-use your head bolts?
    Travis
  • lyndon sharpton
    Re: C3 (70) Head Gasket type?
    what size is your engine?
      • 43222
      Travis-----
      Steel shim gaskets were originally used for all 1970 applications. For replacement, I recommend Fel Pro Permatorque. These are expensive gaskets (about $45/EACH), but they're worth it. There are even better (and, more expensive) gaskets out there now, but you don't really need them for a cast iron engine.
      As far as the head bolts go, if they are first-run bolts (i.e. they've been in the engine since new and are being removed for the first time), then they're ok to re-use. If they have an uncertain history, I'd replace them. Small block head bolts now available from GM have a different head configuration than originals. There may be aftermarket bolts available through sources like Pioneer Engine Parts and others that are similar to originals, though.
      • Clem Z.
        • January 1, 2006
        • 9427
        if the bolt threads are rusty i would not reuse them unless you are chasing points because they may have a lot of the thread material gone
        • Travis Williamson
          Thanks guys.
          Joe, do you know if the dimensions are the same for the Fel-Pro as the OEM gasket?
          Just wondering what will happen to the compression ratio of the motor.
          • Travis Williamson
            L-46 small block 350
              Travis -
              The OEM steel shim gaskets are about .019", and the Fel-Pro composition gaskets are about .039"; going from OEM to the composites will reduce compression by about one-tenth of a point.
