'67: removal of differential mounting brace - NCRS Discussion Boards
  • Barbara S.
    • April 30, 1981
    • 599
    I've got my '67 frame stripped to the bone except I can't figure out how to remove the steel differental mounting bracket/brace from the frame. I've loosened both bolts but it still won't budge. What is holding me up?
    Thanks.
    Tony
  • William C.
    • May 31, 1975
    • 6037
    Re: '67: removal of differential mounting brace
    use of a long pry bar and a lot of force are all that are standing in your way.
    Bill Clupper #618
    • Richard Hayes
      Tony,
      Before the prybar- hit the rubber mounts with a propane torch. Works everytime for me.
      Richard
      • Rob A.
        • December 1, 1991
        • 2126
        Tony,
        If you haven't gotten it off yet, after you remove the bolts, you might want to loosely install longer ones in place, so when it comes loose it doens't come flying down.
        • Barbara S.
          • April 30, 1981
          • 599
          Thanks Rob. I used a shorter pry bar yesterday, but it wouldn't budge.
          Tony
          • Rob A.
            • December 1, 1991
            • 2126
            Tony,
            I can't remember, but I think I was able to squirt some WD40 between the frame and the top of the mounting cushions, which I let sit a day before prying it off.
            • Craig S.
              • June 30, 1997
              • 2471
              Tony - on my 67 I used a 3 -4 foot pry bar, and I also used a 3 leg puller on the sombrero at the same time. As Rob suggests, I used a longer bolt also to control the drop when it popped loose.....Craig
