rocker panels 70-72 - NCRS Discussion Boards
rocker panels 70-72
  • lyndon sharpton
    rocker panels 70-72
    what is the best way to the old coating off of the rocker panels? the anodized on the aluminum. sand it off? are can you use some kind of striper to take it off? thanks
  • Jim S.
    • March 1, 1986
    • 1402
    Re: rocker panels 70-72
    Lyndon,
    If You are going to restore them don't do anything ..Let the plater strip them and re-anodize them.
    I had mine stripped By buffing them out. I then took them to the anodizer who said he would not re-anodize them now because the buffing process impregnated little bits of anodize into the aluminum and they would have to sit too long in the tank to get them all out. The best laid plans..........
    If however you dont plan to reanodize them than a good buffing will sure make them look great , at least for awhile !
    Jim
    • Gary S.
      • July 31, 1992
      • 1632
      What plater did you use that had a tank long enough for a rocker molding? I need to have a set done but havent' seen anyone that will/can do it.
      Gary
      • Thomas E. Zales
        How long is the part. I owm an anodizing business in NC.
        Tom
          • 11643
          You might be our new best friend.
          I'd guess 4 feet long, but my cars are not here to measure.
          Anyone able to check?
          I have two sets (4 panels) that need work.
          Patrick
          • David D.
            • 330
            Tom, 65.5 inches long. Dave
            • lyndon sharpton
              can you do the long parts in your tank? say at 66" are so?
              • Jim S.
                • March 1, 1986
                • 1402
                I dont remember since I didn't get them done. It was an anodizing plant in Tempe Az. I will try to get a name for your tomorrow.
                Jim
                • Ralph A.
                  • May 31, 2002
                  • 236
                  Add me to the list of neeed 2 redone.
                  RA
                  Ralph Adams
                  NCRS: 38137 LA: 112
                  Slidell, LA 70461
                  1969 350/300 LeMans Blue Conv (restoring)
                  1971 350/270 Bridgehampton Blue Conv (top flight)
                  1972 350/200 War Bonnet Yellow Conv (restoring)
                  2001 Bowling Green Metallic Conv (fun car)
                  • Thomas E. Zales
                    email me @ ppmachining@northstate.net w/phone #. I will call & let you know size information.
                    Tom
