C3 (72)Buzzers - NCRS Discussion Boards
C3 (72)Buzzers
  • Rob C.
    • August 31, 2004
    • 144
    C3 (72)Buzzers
    Could some one tell me were the ignition and the seat belt warning buzzers are in a 72 convetable small block.
    Thank you Rob
    • 43232
    Re: C3 (72)Buzzers
    Rob-----
    They are both located behind the dash panels and are "plug-in" type buzzers which are inserted into connectors in the dash wiring harness. The ignition key warning buzzer is approximately above the speedometer. The seat belt buzzer is approximately to the right of the center cluster. The same part is used for both of the buzzers and is GM #6262663. It's still available from GM under that number for about 25 bucks, GM list.
