62 vette air filter - NCRS Discussion Boards
62 vette air filter
  • John O.
    • May 31, 1998
    • 480
    62 vette air filter
    Hi all.
    I just need some info on the filter. I bought the air filter used. My question is, my filter has a sponge type material going around the inside held against the cover with a type of wire. Is this the correct filter? Can this material be washed and reused? Where can more material be bought if I have to replace it?
    Thanks,,,,John
  • Chris H.
    • April 30, 1990
    • 817
    Re: 62 vette air filter
    Sounds like the right one. I know Paragon carries as 552 for under $11..
    I washed mine in soap and water and then saturated with engine oil. Still getting some excess running out so do not use to much oil.
    chris
    • William C.
      • May 31, 1975
      • 6037
      I believe instructions for cleaning.reoiling are in the owners manual.
      Bill Clupper #618
      • John O.
        • May 31, 1998
        • 480
        Thanks Chris and Bill.
        I did not know that you use oil on the filter.But i'll read the owners manual.
        John
