C2 Starter/Solenoid? - NCRS Discussion Boards
  • Les Jacobs
    Until today, the starter had worked perfectly. While cranking the engine(and before it fired up) , I let the key move from the "Start" to "Run" positon. The starter disengaged but continued running. So I flipped the key "Off", and it still ran. Next, I disconnected the battery terminal and it stopped, but restarted after I touched the terminal to the battery post. After a couple attempts the starter remained quiet, then drove the old girl home. Does this sound like a solenoid problem, and if so should it be repaired or replaced? Thanks Les
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: C2 Starter/Solenoid?
    The internal contacts are sticking together. Take it apart, turn the post around, polish the disc. It should be good for another 40 years or so.
    • Les Jacobs
      Thanks Wayne- NM *NM*
