C2 underhood heat blistering - NCRS Discussion Boards
  • Ron Hambrecht
    I am having a problem with the black underhood paint blistering from heat over my expansion tank.
    I used Dupont chasis black. Any suggestions for a high temp solution ?
  • Joe R.
    • July 31, 1976
    • 4550
    Re: C2 underhood heat blistering
    Ron,
    GM solved that problem several years ago with an underhood blanket. I cannot imagine the overflow tank getting hot enough to bubble the paint. I also cannot understand your use of GM Chassis Black on the underside of the hood. Visit Wal Mart and purchase some Krylon 1613 Semi-Flat Black. I've used it with no problems of bubbles from heat. It is enamel paint and very durable.
    JR
    • Larry S.
      • August 31, 2000
      • 356
      Did it show up after having the car in a car show with the hood open?
      • Don 42616
        Sun reflecting off air cleaner will burn a hole ! *NM*
        • Ron Hambrecht
          Re: Sun reflecting off air cleaner will burn a hol
          No, it starting showing up after the hood (and the entire car was painted). I asked the shop what they used, and they said "Dupont black, and that maybe the paint was contaminated". They re painted it. I had te car out yesterday, temp usually around 200 - 210. it started to blister again.
          Does anyone know of black high temp paint I could use ?
          I already had the car top flighted twice, so I am not concerned about correct paint.
          • Joe C.
            • August 31, 1999
            • 4598
            Eastwood's "Underhood Black" lacquer. Buy in 1 qt. cans, thin 1:1.
            Joe
