C-2 Wheel Trim Ring Instruction Sheet - NCRS Discussion Boards
  • Rick S.
    • January 1, 2003
    • 1203
    What should I look for when buying a Wheel Trim Instruction Sheet, part # 3913832 for a C-2 (1967)? Thanks in advance.
    Rick
  • Brian M.
    • February 1, 1997
    • 1839
    Re: C-2 Wheel Trim Ring Instruction Sheet
    The one that is on E-Bay "appears" to be the real thing. I'd ask questions to be sure that it's not just a copy.
    • Peter L.
      • May 31, 1983
      • 1930
      Rick - Be sure to consider when your car was built/shipped and if it you'd expect it to have come with the Trim Ring Instruction Sheet. Being that the Trim Ring Instruction Sheet shows a 9-23-66 date and if that's the print date or release date, I wouldn't think early '67 cars (Sept 1966) would have one. Pete
      • Sal C.
        • December 1, 1984
        • 430
        Make sure you look for a paper (cardboard) thickness of about 3 times that of the repros.
        • Brian M.
          • February 1, 1997
          • 1839
          The thickness should be of a business card. The wording is misplaced on the repro's that I've seen.
          • Rick S.
            • January 1, 2003
            • 1203
            Pete,
            The car is a June 67 build date, so is the date on the instruction sheet okay? Did they have different dates?
            • Rick S.
              • January 1, 2003
              • 1203
              Brian,
              What do you mean by "the wording on the repro is misplaced"?
              Rick
              • Peter L.
                • May 31, 1983
                • 1930
                Rick - As far as I know there was only one date, but I just wanted you to check and make sure the car would of had one before you went thru the trouble. Because as I indicated early cars (Sept 1966), I would not expect to have come w/ the Sheet. Pete
