1970 corvette front grille - NCRS Discussion Boards
  • Jack bogosian
    There is a space between the middle grill and the right grill about a half in the on on the left seams to be closer and better lined up.. This right on is down about quarter inch lower then the middle one the seams is not lined up can I bend it up or is there a bracket I can replace , Thanks JAck
  • Tony H.
    • May 31, 1993
    • 537
    Re: 1970 corvette front grille
    Looks like your Corvette is original. Mine is similar to yours although I do not recall whether it is the left of right side that is closer. I'd leave it alone, otherwise, you are restoring it better than original.
    Tony
    • Jack bogosian
      thanks Tony I feel alot better knowing that it is normal to be off a little THANKS JACK
