How do you get the wood off the door panels I would like to replace just the woo I bought it already.. Also both sides the door panels are poped off the door at the front bottom where do you put the screw to hold on the door panel to the door.. Thanks Jack
1970 corvette wood on doors
Re: 1970 corvette wood on doors
The simulated wood insert is attached with adhesive. You should be able to peel it off if you lift a edge and use a flat wide tool like a putty knife to lift if off. Hope your new ones fit. I bought some to replace the originals on my 70 and the fit was poor, the size was off, the entire unit was to small for a good fitting in place of the original. The 70's door panel is attached at the bottom with 2 plastic retainers that somewhat mesh together to hold. Near the rear bottom there should be a thin metal piece that is attached to the inside of the panel that uses one phillips head screw to attach the metal brace/bracket to the door.- Top
