C3 350 Front Brake Job - NCRS Discussion Boards
  • Tony
    Greetings.
    I have a leaky front Right caliper. I purchases Cardone reman calipers with new pins and new semi-metallic pads. I've also ordered speed bleeders for the calipers. The rotors look good.
    Is there anything in particular I should be aware of aside from the routine servicing/replacing of the calipers?
    I was also thinking of replacing the rubber line for the stainless braded line. Your thoughts, please.
    Thank you.
    Tony
    • 43221
    Re: C3 350 Front Brake Job
    Tony-----
    I don't recommend the stainless steel braided lines. However, if you do use them, make sure that the ones you purchase are DOT-approved AND CLEARLY STATE THAT FACT on the packaging. Not too many of these are DOT-approved.
    • Michael W.
      • April 1, 1997
      • 4290
      I'll second Joe's opinion of staying away from the stainless steel braided lines. DOT approved or not, these lines have little or no practical benefit for a street driven car. They are NOT an 'upgrade' in any sense of the word.
