C1 Differential Gear Change - NCRS Discussion Boards
  • Ed T.
    • November 1, 2002
    • 95
    My 62 has a 4.11 posi rear. A bit too much gear for cruzing. I would like to change the rear gear ratio to something in the mid-threes with posi. If I understand things correctly, I will need a new carrier that will handle the new gears, because mine will only support the 4.11 and the 4.56 gears. I would sure like your response to the following:
    1. Am I correct that I will need a new carrier?
    2. What parts will I need?
    3. Where can I get the parts?
    Thanks all for your help...Ed
  • Sander B.
    • March 1, 2005
    • 499
    Re: C1 Differential Gear Change
    1 Yes
    2 carrier ( C-30743 ( 3 series)) and ring and pinion
    3 ebay etc....... driveline ?
    good luck !
    Sander,
    • Robert Willis
      Or...... If you don't care about numbers for cruising you can use the whole centre section from a passenger car up till 1964. I put 3.08s in my 57, they are great on the highway but a little slugish around town.
      Bob
      • Ed T.
        • November 1, 2002
        • 95
        Thanks Sander. Getting the parts would appear to be the hard part.
        • Ed T.
          • November 1, 2002
          • 95
          Thanks Bob. My initial goal is to make it a good driver, then improve upon that as time and money goes by. Is there a good source for interchangable part information?
          • Robert Willis
            Ed, right here is about as good a source for info that you will ever find.
            Bob
            Bob's Chevy Corner
