Circa 1970 GM Production Numbers - NCRS Discussion Boards
    • 15601
    Re: Circa 1970 GM Production Numbers
    What do you mean NEW? The FWD?
    Or the real Impala SS -- RWD? I have the equivalent of that one already X2, as you know.
    If you had said OLD Impala SS you could have got my attention.
    • Art A.
      • June 30, 1984
      • 834
      Nope none in GA.
        • 11644
        OK,
        I'll trade you an OLD Impala SS for your car...60s style or 90s style. You pick.
        But I get to pick the car.
        Patrick
          1st-Generation ('67-'69) Camaros were built only at Norwood and Van Nuys (and in Antwerp, Belgium and by the Utivo Hardware Co. in Manila, Philippines); after Norwood and Van Nuys closed, 4th-Generation Camaro/Firebird production was consolidated at the Ste. Therese plant in Quebec, which also closed about two years ago when GM gave up and handed that market segment to the Mustang.
          • David D.
            • April 1, 1990
            • 330
            Terry, Is a 1995 Impala SS to new? Original owner, under 12K miles, all stock except for cat back exhaust, but original pipes available. Dave
              • 15601
              What color is it Dave? It might make a good combination with my two 1995 9C1s. Another whale really isn't too high on my list. I was thinking along the lines of something in the early '60s with aluminum hood, fenders, and a W motor.
              • David D.
                • April 1, 1990
                • 330
                Terry, The 1995 is the Green for that year. As for the "W" motor car, you must mean the factory 1963 lightweight's, but I believe most of those did not come with the SS package. Dave
                  • 15601
                  Dave -- the DGGM (Dark Gray Green Metalic) would clash with my blue (1-dark and 1 light) 9C1s, so I would have to pass.
                  I'll have to look some more at those aluminum nose B-bodies. You might be right. I don't hold out much hope anyway. I'll just stick with the plastic car.
