The 67 AIM shows a 3884575 thin stainless steel baffle on top of a 3890495 gasket to the intake manifold. I bought a carb kit and it came with a heavy duty gasket with a dogbone shaped cutout on the vacuum fitting side (it says TOP on one side).
Did the original 3890495 gasket have this same dogbone cutout? It seems to me that if you use dogbone gasket with the baffle on top, the dogbone cutout has no purpose.
Is the gasket with the dogbone intended to eliminate the stainless steel baffle or does it have something to do with heat transfer. Or do I have the wrong gasket for use with the baffle?
Jerry Fuccillo
#42179
Jerry Fuccillo
#42179
