78 AC Compressor - NCRS Discussion Boards
78 AC Compressor
  • Robert S.
    • July 31, 2004
    • 377
    78 AC Compressor
    Does anyone have the correct part number for a mid-1978 AC compressor? TIA, Bob
    Bob
    • 43221
    Re: 78 AC Compressor
    Bob-----
    You didn't mention if you were interested in PRODUCTION or SERVICE part numbers. That's important for an item like an A/C compressor. Anyway, the PRODUCTION part number for most 1978 Corvette applications was GM #1131078. For L-48s with THM-350 and without California or high altitude emissions, it was GM #1131076.
    The current SERVICE part number for the compressor is GM #1134352. This is a NEW compressor assembly with clutch. It carries a current GM list price of $405.37.
    You can also obtain rebuilt units from Delco under Delco #15-2232 (with clutch) or 15-2201 (without clutch).
    • Robert S.
      • July 31, 2004
      • 377
      Thanks, Joe!!! You have answered my question and then some. I was looking for the correct original number. The info on the service unit is helpful too. By any chance do you know what the application of 1134354 is? Someone told me it was a replacement for the orig 1131078!?!
      TIA
      Bob
      Bob
        • 43221
        Bob------
        That's exactly what it is-----a current replacement for the original. That's why I mentioned the part number. Of course, it likely has a lot of other applications, too. However, it's the correct current replacement for your application.
          • 43221
          Correction
          Bob-----
          I mis-typed the part number of the SERVICE compressor in my first response. The number should be GM #1134354 for your application which replaces the original part number 1131078.
          It just so happens that GM #1134352, which I incorrectly typed, is actually an A/C compressor, too. However, it's applicable to some 85-87 GM models and no Corvettes.
