Headlight Bucket Plugs - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    It's not very clear from the AIM, or LICS catalog, but how do the plastic plugs get inserted: from the inside-out, or from the outside-in. Either way, they are a PITA, because they either rub on the inside of the header, or they hit the pivot mount bolt heads.
    Thanks in advance.
    Joe
  • mike mccagh
    Re: Headlight Bucket Plugs
    i assume you're referring to the c-2 heaslight buckets, and if so, the plugs insert from inside the bucket. mike
    • Rob A.
      • December 1, 1991
      • 2126
      Joe,
      The plugs from LIC are really tight. I don't think they are really the exact size as originals, but are the closest thing available. The originals I have are not that difficult to put in. They have to be inserted from the inside because they go on after the hole is used to put the three bolts in place.
