1966 Coupe on ebay - NCRS Discussion Boards
1966 Coupe on ebay
  • Ken K.
    • May 31, 1999
    • 235
    1966 Coupe on ebay
    Check out this 1966 Corvette on ebay. I wish all cars were listed this way. (Nice presentation.)
    Ebay Item Number: 4552806921
  • Mike G.
    • January 1, 1991
    • 418
    Re: 1966 Coupe on ebay
    Really one of the best presentations I've ever seen.
    Did you note that the differential is a non-posi? Why in the heck would the customer or GM equip this car with a standard differential?
    • Larry S.
      • August 31, 2000
      • 356
      Nice car.
      I have some questions about the date codes for the motor so I can better understand date codes ranges.In no way to I mean to change anybodys opion of this car or it owner,And what I ask here in no way should changes someone decistion to purchase the car.
      That being said
      Car was built Oct 15th 1965. (From trim tag)
      motor was cast Oct 4th 1965 (from casting)
      Pad was stamped Oct 13th 1965 (From pad)
      (9 days from casting to being a entire assembly installed in a car WOW that fast). Could someone explain if this is considered a normal time frame.And I know there had to be a week end in there some place.
      • Larry S.
        • August 31, 2000
        • 356
        And YES Ken you are correct its a very nice listing its all meat and potatos (even with out the descriptive numbers and date codes) the person is giving alot of great information on the car and NO FLUFF. and enough photos for you to understand its a High Quaility car.
        Thanks for the link
        • Mike E.
          • February 28, 1975
          • 5139
          Larry--
          Not at all an inappropriate or unacceptable time frame for motor cast, assembled, and in the car.
