frame repair - NCRS Discussion Boards
frame repair
  • William G.
    • April 1, 1978
    • 154
    frame repair
    does anyone have information on having a frame repaired. I have a 1964 coupe
    that needs frame repair on and around the #3 mount in front of the trailing arm. indiana rust
  • Craig S.
    • June 30, 1997
    • 2471
    Re: frame repair
    William - I would consider Grace Way.......see link....Craig
    Graceway Machine
    • Bruce Melvin
      Re: frame repair
      Take a look:
      '63 frame resto
      • Terry F.
        • September 30, 1992
        • 2061
        Re: frame repair
        Beautiful work. I think if I had to do that now that I looked at the process, I think I could. But there would be some time involved in it. Getting back to good steel is the trick and having good frame sections to replace the bad sections with. A lot of work but I would have a ton of fun too. Thanks for showing the pictures! Terry
        • William G.
          • April 1, 1978
          • 154
          Re: frame repair
          craig
          thanks for the response. i am looking for a shop close to Ind, michigan,
          or ILL.
