Brake Return Spring - NCRS Discussion Boards
Brake Return Spring
  • Jill G.
    • August 31, 2001
    • 30
    Brake Return Spring
    I have a 67 with power brakes that is in the final stages of restoration. I am restoring the brake and clutch assembly and noticed that the AIM manual as well as the vendor catalogs show a brake return spring for manual brakes but do clarify if one is also required for power brakes. Does the 67 power brake pedal assembly also require a brake return spring like the one for manual brakes? If so, I need to order one. Thanks for help on this.
    Re: Brake Return Spring
    Paul -
    The power brake arrangement doesn't require the coiled pedal return spring; with power brakes, the booster provides the pedal return function.
