Muncie 4 SpeedTransmission - NCRS Discussion Boards
  • Don kelley
    I an trying to determine what year this transmission is:
    I have a rear casting number of 852254 and a code stamp of O 3 1 could be D3 1
    I am somewhat sure the D 3 1 means a April 3th of a 61 71 or 81. I am hoping my casting code will tell which of the 3 years.
  • William C.
    • May 31, 1975
    • 6037
    Re: Muncie 4 SpeedTransmission
    What is the casting number on the side of the main case? There will also be a number starting with a "P" stamped into the side of the main case toward the rear of the main case. These are the numbers you need to ID the trans, but it is not a '61, (None Built) and Muncie had ceased manufacturing after '75 or so, so it isn't an '81.
    Bill Clupper #618
    • mike cobine
      Since there were no Munices in '61 or '81, it would have to be '71.
