Was a spacer used between the 4 blade fan and the WP pulley in 1959? What benefit would the spacer add? Thanks again. Pat G.
C1 fan spacer
Re: C1 fan spacer
My 59 had a spacer behind the fan before my rebuild. However, I read somewhere that a spacer was not installed on 59's, but rather was included on the 60 model to aid cooling. Naturally, I will add the spacer back if I'm incorrect, but would like some additional expert opinions.- Top
Re: C1 fan spacer
While I'm certainly not an expert, I'll throw in my .02. The 59 fan shroud is alot different than the 60. The top of it is several inches thicker so the 59 didn't use a spacer. The spacer was used on the 60's that didn't have the temp. controlled fan. The fan should be flush with the opening of the fan shroud.- Top
