'54 vette carb rebuilding kits - NCRS Discussion Boards
  • Howard S.
    Infrequent User
    • February 1, 1993
    • 1
    Looking to locate rebuild kits for '54 carbs. Many will rebuild for me, but I only need to locate someone who makes the kit to finish engine rebuild myself.
  • Mike M.
    • May 31, 1974
    • 8396
    Re: '54 vette carb rebuilding kits
    carter made master rebuild kits for the 53-4 vette Y carbs. local NAPA type auto store ought to be able to get them for you. good luck, mike
    • Roy B.
      • February 1, 1975
      • 7044
      Go on line look under Corvair parts , the Corvair Turbo used the same Carb same parts, same kit, they go for about $20.00 . They also offer to restore your carb for MUCH less then Corvette shops.
      • Jimmy J.
        • May 31, 1988
        • 304
        Try Daytona Parts Co. 386-427-7108. Click the link below for web site. Jimmy
        Daytona Parts Co. A premier supplier of high quality carburetor repair kits and Ethanol resistant carburetor component parts for carburetors, from 1923 thru today
        • Robert Willis
          I found Car Quest had a listing and were in the warehouse. Also used in Marine Applications.
          Bob.
