Midyear Dash Removal - NCRS Discussion Boards
  • Dean
    With nothing but the dash shell and pads remaining, how do you remove the dash? It appears, in addition to the bolts under the windshield, five rivets on each side (door jam area) must be drilled out. How is the center section attached to the transmission tunnel area? Any information or helpful hints on the removal and installation of the dash would be greatly appreciated!
  • Kenneth S.
    • July 31, 1981
    • 302
    Re: Midyear Dash Removal
    The bottom center of the dash is bonded to the transmission tunnel. Use a sharp chisel and very carefully break the bond so as not to ruin the dash.
