C2 L79 Alternator belt length? - NCRS Discussion Boards
  • Mike Swanson
    I am looking for the correct length alternator belt for a C2 L79.
    NO Air, NO PS, NO PB. I think the one I have is too long. I have to pull the alternator all the way back in the arm slot for proper tension.
    The TM&JG says it should be 3/8" wide but does not specify a length. I looked for one last night at an auto parts store but all they had was a Gates with the notches in it.
    Mike
  • Wayne M.
    • March 1, 1980
    • 6414
    Orig was #3871257: 3/8" -- 54_3/4" lg. *NM*
    • Mike Swanson
      Re: Orig was #3871257: 3/8" -- 54_3/4" lg.
      Thanks Wayne! Just what I needed.
      Mike
      • Mike Swanson
        Wayne,
        I should have been more specific. I think that number is for a '65. I think a '67 used a 3861946. Do you know if they are the same length?
        Thanks again...Mike
        • Wayne M.
          • March 1, 1980
          • 6414
          # 3861946 shows as 54" even
          I should'a specified that the other belt was for '65.
          Sometimes I forget they made other Corvettes
          • Rob A.
            • December 1, 1991
            • 2126
            Re: C2 L79 Alternator belt length?
            Mike,
            I just replaced the alternator on my '66 L79 for the same exact reason. I bought one at Autozone. Nothing fancy, but they come in a varity of lengths. I Found one that was about 1/2" shorter, #15540-11AV1370 and now the alternator adjustment is about in the middle with the proper tension.
            • Rick S.
              • January 1, 2003
              • 1203
              Re: # 3861946 shows as 54" even
              Wayne,
              What would be the part number and proper length for a 1967 L79 with PS but no AC or AIR?
              Thanks, Rick
              • Mike Swanson
                Rick, I believe that it is the same #3861946. I looked on the Quanta web site at their GM restoration belts and it lists the same #
                Mike
                • Brian M.
                  • February 1, 1997
                  • 1839
                  If you are going to use Quanta belts get them from Quanta and not from LIC, they sell a generic size that is too long and they don't care to correct this issue.
                  • Patrick T.
                    • September 30, 1999
                    • 1286
                    My car and engine is the same as yours. I bought two belts from two different vendors that were original in appearance for a L-79. They were both too long. After some discussion with a couple vendors, I bought a small block belt for a base motor (300HP) and it fit perfect, the alternator bolt is right in the middle of the arm slot. Don't know what the confusion is with the vendors though. PT
