TCS 71 454 - NCRS Discussion Boards
TCS 71 454
  • lyndon sharpton
    TCS 71 454
    I need help on how to run the TCS on my 71, the wire that comes up from the trans switch, what does it hook into? any one have a diagram of the TCS?
  • Gary S.
    • July 31, 1992
    • 1633
    Re: TCS 71 454
    Lyndon, do you have the GM 1971 Service Manual? My 72 manual has the TCS wiring in it, as well as a diagnostic process for figuring the system out. If you don't find it, email me off line and I will scan the page for you. Pretty straight forward design.
    Gary
    • Dick W.
      • 10483
      Re: TCS 71 454
      Gary, Lyndon, the 71 shop manual does not have the correct wiring schemetic for the TCS. Use the 72 shop manual and other than the solenoid, everything else is the same. GM mistake but probably the only one that they have ever made.
      Dick Whittington
      • Gary S.
        • July 31, 1992
        • 1633
        Re: TCS 71 454
        Since I only have the 72 manual, it looks like I may be able to copy that then. Thanks.
        Gary
        as mentioned, isn't this a CEC, which I assumed stands for combined emission control?
        • Dick W.
          • 10483
          Re: TCS 71 454
          Yes, 1971 is actually CEC but functions basically the same as a TCS system
          Dick Whittington
