Mid-Year Horn - NCRS Discussion Boards
Mid-Year Horn
  • Gary Schisler
    Mid-Year Horn
    Richard, ZIP makes a relatively easy-to-use horn rebuild kit. My neighbor and I both bought kits for my 66 and his 73. One of our local salvage yards has a nice selection of late 60's and early 70's GM cars that are good donors for horn parts. I paid $4 for two fully funtional and working horns in very nice cosmetic condition. If you go this route, as a suggestion, when you crimp the new rivets, you will need to use a small bench vise. This gives the rivet head the "cross hatch" pattern that is seen on original rivets. This was an easy task. Just make sure that you watch closely as you disassemble the old horn. A couple of small gaskets and bushings can get lost.
  • Richard Sullivan
    Mid-Year Horn
    One of the horns on my 64 is missing the tab that the electrical wire plugs onto. Is there any way to fix this without having the horn rebuilt (the horn works OK).
    RLS #30956
    • Bill Clupper
      Re: Mid-Year Horn
      Unfortunately, probably not, as the lug is riveted with an electrical connection on the underside and the rivet goes thru an insulator. The shell must be disassembled to access it, so effectively at that point you are well along on a "rebuild"
      • Chuck G.
        • May 31, 1982
        • 2034
        Re: Mid-Year Horn
        I have 2 friends, both NCRS members here in Baltimore who rebuild horns. EMail me and I'll put you in touch. Agree with Clup that you have to disassemble the horn to replace the lug....then you have to re-rivet it back together with the correct rivets, with the correct tension, etc. It's like "tuning" a snare drum. It's harder to do than it looks. Chuck
