C1 Vapor Lock - NCRS Discussion Boards
C1 Vapor Lock
  • John C.
    • September 30, 2001
    • 130
    C1 Vapor Lock
    I live in Northern California and yesterday we went on a C1 and C2 run we had about 41 cars, the temp was about 96 degrees twice I experenced vapor lock my car is a 59 283 single 4 barrel, can someone please tell me what causes this and how do I correct this problem. Thank You
  • Brad K.
    • August 31, 1990
    • 414
    Re: C1 Vapor Lock
    The fuel line from the fuel pump to the carburetors on the early vettes runs VERY close to the head and just behind the right side of the front engine mount. If it is touching one of these components it can easily cause vapor lock. It used to happen to me all the time until I removed the fuel line and wrapped it with some insulation.
    • John C.
      • 130
      Re: C1 Vapor Lock
      Thanks Brad I will try that
      • Mark B.
        • February 1, 2004
        • 138
        Re: C1 Vapor Lock
        John, the same routing for the fuel line occurs not only on my 59, but on my 62 also. I have found that if you take a piece of 3/8-inch rubber fuel line and slit it open along its length, it can be used to cover the exposed fuel line next to the head on the passenger's side. I use either plastic electrical ties or some black silicone on the inside to keep the hose around the fuel line. It helps considerably. Good luck.
        • Michael D.
          • August 31, 2001
          • 63
          Re: C1 Vapor Lock
          IS THIS THE JOHN CLEMENTS FROM HOT AUG NITES WITH THE RED/WHITE 59?
